What code reader for 2000 Neon
Old Nov 30, 2005 | 01:37 AM
thonczarenko's Avatar
thonczarenko
Default What code reader for 2000 Neon
Does anyone know which one is good and cheap? My Neon is running on 3 cylinders (feels like), and I need a cheap way to diagnos the problem.
Thanks in advance!
Old Nov 30, 2005 | 04:02 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: What code reader for 2000 Neon
its OBD2 you can buy some for as low as 50 dollars....to 100 all the way to the universal engine diagnostic computers which can go to who knows....
Old Nov 30, 2005 | 05:22 PM
thonczarenko
Thanks! Do you know of any, and have a link to one?
Old Dec 1, 2005 | 07:20 PM
tooslow's Avatar
tooslow
if just trying too find out what causing the code the car will give it without the obd2 just turn the ignition of/on/of/on na it will display the code where the millage is on a 2nd gen
here is a link too the codes
03+
00-02 codes
hope it helps
thx Danny
Old Dec 1, 2005 | 07:51 PM
thonczarenko
I was told that is how to check on a '99 and older. Are you sure that will show the codes? I will check after work; I hope it works!
Thanks!
Old Dec 1, 2005 | 07:54 PM
tooslow's Avatar
tooslow
it work on my 03 so it should work on yours
Old Dec 2, 2005 | 01:09 AM
thonczarenko
Thanks!!! It worked like a charm. My #2 injector is bad.
Thanks again!
Old Dec 2, 2005 | 03:10 PM
tooslow's Avatar
tooslow
what code are you trowing because if it is only a misfire code it could something alse and not the injecter
I am glad it helped
Danny
Old Dec 7, 2005 | 03:16 PM
thonczarenko
It turns out that you are right; I played around with the wiring harness and the car is running fine now. I have to look into the cause, but it is either a corroded connector or a cut in the wire and it is grounding out.
The code it was throwing was P 0202 and P 0302 and another, but I forgot what it was. It said that it was detecting a miss in cylinder #2 and the #2 injector had and open ground. The other one was that the battery was disconnected within the last 50 starts.
Thanks again for all of your help!!!
