2002 dodge neon fog lights stuck on?
Old Mar 5, 2018 | 08:25 PM
Jesse Threlfall's Avatar
Jesse Threlfall
Default 2002 dodge neon fog lights stuck on?
Anyone else have this issue ? MY fog lights stuck on when I turn on the low beams. Even if the fog light button is depressed . If I figit with the button they flicker on off but remain on ? ANY suggestions?
Old Mar 5, 2018 | 09:04 PM
Button probably need to be replaced.
Old Apr 19, 2018 | 12:30 PM
AngusarusRex's Avatar
AngusarusRex
I had the same problem in my '05 Neon. If i pushed the stalk forward, or if I pushed the fog light switch back in, The fogs turned off.
You have to replace the entire stalk to fix the issue. That was the only method that worked for me.
