replacing axle seals without a needed an alignment after
Old Aug 29, 2018 | 04:22 PM
mike L's Avatar
mike L
Default replacing axle seals without a needed an alignment after
I just found a leaking axle seal, and it's time for a transmission oil change.
How can I replace both axle seals without needed a 4 wheel alignment? I just had one done last week.
Old Aug 29, 2018 | 08:08 PM
otis_771's Avatar
otis_771
Disconnect lower balljoint pinch bolt instead of strut bolts, may also need to disconnect tie rods from knuckle to get axles out
Old Aug 30, 2018 | 10:54 AM
mike L's Avatar
mike L
So how can I break loose the balljoint from the steering knuckle without damaging the ball joint?
Old Aug 30, 2018 | 11:33 AM
Rent a ball joint press from your local parts store.
Old Aug 30, 2018 | 11:47 PM
primem's Avatar
primem
remove the ball joint nut and or thru bolt... put a chain around the control arm near the ball joint end and put a bolt thru the links to form a loop of chain. slide a big pry bar thru the chain. push down on the pry bar and it will pull down the control arm away from the knuckle. have some one hit the knuckle where the ball joint stud goes thru it. the shock will release the bj where is stuck in the taper of the knuckle.
