turbo
Old Dec 8, 2005 | 06:11 PM
06srt4neonwannabe's Avatar
06srt4neonwannabe
Default turbo
Ok so i just bought a 2006 neon 2.0 basic everything its in the shop right now getting its new seats stero speakers body kit cosmetics the stuff i cant do. What im trying to find out is there a kit for a turbo for a 2.0 motor or anything that will get me faster and more racer to step with the big v8s HELP
Old Dec 8, 2005 | 07:10 PM
03neonRT's Avatar
03neonRT
Default RE: turbo
Yes, there is a Hahns Racecraft turbo for the 2.0 SOHC, runs about $3k-$3500 depending on which one you get and whether you install it yourself or have a pro do it. Ive heard that you can run about 12psi of boost if you have a magnum egine, so with the standard 2.0 it miht be a bit less. Th kit should be able to pout out about 27psi of boost according to the Hahns website, but that would be with quite a bit of work to the internals of the engine.
But if you have the money for a turbo and everything, why didnt you just buy an SRT-4???
Old Dec 8, 2005 | 10:28 PM
Somethingdirty's Avatar
Somethingdirty
Default RE: turbo
2006 neon? I'm confused, the 2006-up neon was discontinued.
Old Dec 8, 2005 | 11:29 PM
03neonRT's Avatar
03neonRT
Default RE: turbo
Yeah i dont think they are making a 2006 model year Neon, but maybe they are just using the last of the 2005's and calling them 2006 models like Ford did when they discontinued the Taurus in 2004...
Old Dec 9, 2005 | 04:21 PM
casper's Avatar
casper
Default RE: turbo
LOL, you bought the only 2006 neon out there, they were discontinued in 05!!!!!!!!!!!!
Old Dec 12, 2005 | 05:03 PM
tooslow's Avatar
tooslow
Default RE: turbo
actaully the base 03+ model would be able too handle more boost than the r/t models because it has a lower compresion ratio that the r/t and all soch neons that came before it
Old Dec 12, 2005 | 07:23 PM
QuickSilver05's Avatar
QuickSilver05
Default RE: turbo
I didn't think you could turbo the standard 2.0 because of weaker internals. Am I mistaken?
Old Dec 12, 2005 | 07:28 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: turbo
itll always bring lower CR #s when we are talkin bout SOHC engines...the DOHC is always higher...doesnt make it any safer....
Old Dec 12, 2005 | 09:00 PM
casper's Avatar
casper
Default RE: turbo
ORIGINAL: QuickSilver05
Not 100% sure on the second gen, but not much is different. The 1st gen bottom end can handle up to 300hp. Both the hahns and chill factory kits will bolt onto a stock motor. Now it is going to shorten life a little, but its pretty dependable.
