2001 r/t Timing belt ?!
Old Jan 29, 2019 | 04:26 PM
01neonRTwhite's Avatar
01neonRTwhite
Default 2001 r/t Timing belt ?!
hi I just acquired a 2001 neon r/t from my neighbors, they say the timing belt snapped and I could get away with putting a belt. After digging around in the center console I saw a paper from a mechanic saying it had a code for po430, I was wondering if the snap caused this or my belt isn’t snapped and just need a new sensor. If it does need the whole kit to replace does anyone have a link to change it ?
anything helps thank you !
Old Jan 29, 2019 | 09:14 PM
Does it run?
Old Jan 29, 2019 | 09:16 PM
01neonRTwhite
Originally Posted by jkeaton
Does it run?
no not in years owner didn’t want to fix it so it’s beer sitting for years I’m charging the battery right now which holds 12 volts
Old Jan 30, 2019 | 07:30 AM
Need to make sure it has a timing belt installed first of all.
Old Jan 30, 2019 | 12:31 PM
01neonRTwhite
where is that at ?
Old Jan 30, 2019 | 12:53 PM
Passenger side of the engine. The code you listed pertains to the catalytic converter and has nothing to do with the timing belt. You need to verify the timing belt is not broken before attempting to start it or you will damage the engine permanently.
Old Jan 30, 2019 | 01:02 PM
01neonRTwhite
my bad I mean code po0340 camshaft position sensor malfunction but I will check
Old Jan 30, 2019 | 01:16 PM
Oh, thats different...lol...there should be an inspection cover you can remove to see the timing belt.
Old Mar 28, 2019 | 08:50 PM
01neonRTwhite
Default finaly
Is it toast ?
Old Mar 28, 2019 | 09:59 PM
If it’s an interference engine, yes,, need to pull the heads and see what damage has been done to the valves and pistons.
