2004 SXT horn stopped working
Old Apr 26, 2019 | 09:25 PM
metmacfab's Avatar
metmacfab
Default 2004 SXT horn stopped working
After using the horn during a couple of emergencies, the horn just stopped working. these were very quick hard uses, but if the fuse, relay and horn is good, any ideas would be appreciated.
Old Jun 26, 2019 | 12:11 PM
paw paw's Avatar
paw paw
I see you don't have any replies, so I'll see if I can get things started.
Scan for trouble code clues & post All code Numbers, as they can help focus a trouble shoot.
If no code clues, you said IF the horn fuse, power relay & horn check out ok, so did they check out ok? If so, have a look at the steering wheel horn clock spring, horn contacts & wiring.
Some initial thoughts for consideration, let us know what you find.
