Engine mount bracket problems.
Old Dec 19, 2005 | 04:03 AM
leftfun's Avatar
leftfun
Default RE: Engine mount bracket problems.
pro dudes!!!
so great~~that means i can ask u guyz about the car problem after i buy a neon
Old Dec 19, 2005 | 08:50 AM
RadarLove's Avatar
RadarLove
Ah yes... I remember trying to get mine off the first time. I had even started to drill a hole through the fenderwell to get to those bolts before my wife stopped me and recommended just jacking the engine way the hell up... I knew there was a reason to keep her around
Old Dec 19, 2005 | 03:39 PM
casper's Avatar
casper
ORIGINAL: colton_levi
Alright I'm done whining. After seeing this guy's website neon timing belt I got the courage to just jack the engine way up so that the entire bracket clears the frame rail. To finally get the bracket off I had to jack the right side of the engine up about 7 inches. Now the new water pump and timing belt are installed. Tomorrow I'll reinstall everything else and hopefully take it out for a successful test drive. I just hope nothing is messed up from jacking the engine up to such an extreme angle.
You may have worn the motor mount a little, but thats about it. You will be fine.
