how much ac refrigerant does my 04 sx 2.0 hold? having issues with my windshield fogging up now that is -30 degrees C here. my ac pump is now pumping so going to start by checking if i have the right amount of refrigerant in the system and go from there. the heaters cores does look fun to do on these cars so want to start with the simple stuff thanks
If your smelling coolant in the cab & seeing a coolant drip at the rubber AC condensate drain, under hood in the firewall, put a heater core leak high up on the suspect list. More thoughts for consideration, let us know what you find.
