P0335 Crankshaft bad?
Old Dec 22, 2021 | 10:00 PM
  #21
paw paw's Avatar
paw paw
You've been busy on this puppy. So as I see some piping coming up the passenger side front, where the power steering pump would be, where does it it get relocated to???
Old Dec 22, 2021 | 10:04 PM
  #22
Nilo420's Avatar
Nilo420
It is still there just hidden got to get the exhaust done tomorrow. I will bolt the tubing down so I don't get any rub on the hood. This should be done by the new year. Only need to make a t fitting for my oil feed line and my oil return. Then 3 v bands welded.
Old Dec 26, 2021 | 03:39 PM
  #23
Nilo420's Avatar
Nilo420
got the turbo Watergate set to 4.7 lbs spring and the boost controller set to 4 lbs
Old Dec 28, 2021 | 08:03 PM
  #24
Nilo420's Avatar
Nilo420
Got the turbo and manifold bolted up just need the v bands welded and the oil return line cut to length and I should be good
Old Dec 28, 2021 | 08:34 PM
  #25
paw paw's Avatar
paw paw
Any loss yet of right foot control from heel to toe palpitations, in expectation of what its gonna be called on to do to the Go pedal !!! lol
Old Dec 29, 2021 | 02:25 PM
  #26
Nilo420's Avatar
Nilo420
I just need the t for the oil feed and I should be ready to hit that go pedal lmfao 🤣🤣🤣 believe me I will post a video when everything is zipped up and running
Old Jan 3, 2022 | 06:20 PM
  #27
Nilo420's Avatar
Nilo420
Well I have the exhaust peices welded pick them up tomorrow morning just need to get a t made for the oil feed and we will be putting it back together
Old Jan 3, 2022 | 09:26 PM
  #28
paw paw's Avatar
paw paw
With it this close, are you able to keep that right foot palpitation under control???
Old Jan 4, 2022 | 01:45 PM
  #29
Nilo420's Avatar
Nilo420
Lmao it is very hard trying to control it 🤣🤣🤣🤣🤣🤣
Old Jan 4, 2022 | 04:38 PM
  #30
Nilo420's Avatar
Nilo420
Oil drain is installed and I have everything ready to bolt it back up
