BELT QUES
Old Dec 18, 2005 | 01:31 PM
dirtrider222's Avatar
dirtrider222
Default BELT QUES
HEY, I WAS JUS WONDERIN, I GOT A SECONG GEN NEON WITH POWER STERING AND A/C, CAN I TAKE OFF THE BELT THAT GOES TO BOTH OF THESE ACCESORIES, THIS WAY I CAN PUT IT BACK ON WHEN I WANT TO HAVE PW STERING AGAIN? AND WHEN I DONT I WILL HAVE THE HP GAIN?
Old Dec 18, 2005 | 01:34 PM
Gary Howell's Avatar
Gary Howell
Default RE: BELT QUES
You can an a new Manual Rack will be availible shortly, so you can steer it at low speeds easier.
Old Dec 18, 2005 | 02:54 PM
casper's Avatar
casper
You could do that although its a lot of work to keep taking off and putting the belt back on for a HP or 2.
Old Dec 18, 2005 | 05:52 PM
whyte69's Avatar
whyte69
you could just install an underdrive pulley so that your A/C, water pump, and power steering won't draw as much power from your engine. I can't recall the manufacturer (I THINK it's unorthodox) they make a two part pulley where you can remove the outer ring from it so that your accessories don't draw your engine AT ALL. Once done your racing you can re-fit it back on to your car so you can make use of your accessories again.
Old Dec 18, 2005 | 08:14 PM
Gary Howell
Two peice pulleys come apart once and awhile, that is the draw back to them.
