04 dodge neon 2.0 code p0344
Old Sep 9, 2020 | 08:26 PM
Travis Wilkerson's Avatar
Travis Wilkerson
Default 04 dodge neon 2.0 code p0344
I have a 04 dodge neon I need help with I have the p0344 code I changed the cam sensor twice and looked at the wires everything looks fine it will start up fine and idle fine but when I go to drive sometimes the engine with shut off or won’t let rpms go past 25k and suggestion ps I have no power to the ignition starter wire so I bypassed it with a push button don’t know if that with cause problems but worth a shot any answers are greatly appreciated this is my only car and I need it fixed asap
Old Sep 10, 2020 | 08:12 AM
Are you using OEM sensors?
Old Sep 10, 2020 | 09:54 PM
Travis Wilkerson
I got them 30 bucks at autozone
I got the camshaft and crankshaft and it’s like it got worse I just don’t want the computer to have shorted out
Old Sep 11, 2020 | 08:22 AM
Sometimes only OEM sensors will work.
Old Sep 11, 2020 | 09:02 AM
Travis Wilkerson
so do I have to get them from the dealer autozone and orileys don’t sell them mabey I can go down to the junkyard and snag some just to see if they will work
Old Sep 12, 2020 | 03:34 PM
Travis Wilkerson
I went today and got a mopar sensor and put it on still doing the same thing and it’s throwing the crankshaft code
Old Oct 23, 2020 | 12:30 AM
paw paw's Avatar
paw paw
Bump:
Well Travis its been over a month, so how is the trouble shoot going, 366 curious minds would like to know????
If your still working the problem, maybe have a look-see read here, https://troubleshootmyvehicle.com/ch...e-cam-sensor-1 as the site gives a rather good trouble shooting scenario for both the cam & crank sensors. The P0344 code is more for a intermittent circuit problem, so sounds like a wiring & electrical connector wiggle & sensor thump test may be in order.
Did the problem/s come about suddenly after some event????
