Optima Battery
Old Dec 26, 2005 | 09:16 PM
[DJ]Tomski's Avatar
[DJ]Tomski
Default Optima Battery
Im considering getting an Optima battery but i dont know which one to get. is there a difference between the red and yellow top?
Old Dec 26, 2005 | 09:31 PM
lblackneon's Avatar
lblackneon
Default RE: Optima Battery
I have the red Optima battery. I believe it costed me around $130 dollars and I believe the yellow one is around $30 dollars more. The yellow one is more powerful and it's better for cars with sound systems. I should have bought the yellow one b/c I have a powerful sound system in my car. They're great batteries. The only problem I'm having is my battery is weak b/c I have an AFX underdrive pulley. The aftermarket underdrive pulley sends less power to the alternator; and the alternator charges the battery (on top of that I have a sound system).
Old Dec 27, 2005 | 12:47 PM
Gary Howell's Avatar
Gary Howell
I use the Yellow Top in mine.
Old Dec 27, 2005 | 03:06 PM
[DJ]Tomski's Avatar
[DJ]Tomski
sounds good, ill prolly get the yellow top then. will i have to do anything to the battery tray or will it fit rite in? and whats with the sleeve around the original battery? whats that used for?
Old Dec 28, 2005 | 12:47 AM
lblackneon's Avatar
lblackneon
Gary: I have the AFX underdrive pulley. I've heard that aftermarket underdrive pulleys don't like powerful sound systems b/c of the batteries. That statement made sense to me b/c the aftermarket underdrive pulleys are designed to send less power to the alternator. Do you have an AFX underdrive pulley with a powerful sound system in your Neon and does it make your battery go low?
Old Dec 28, 2005 | 12:19 PM
Gary Howell
They have been tested with a 1200 watt system without any problems.
