Turboing my 2.0l
Old Mar 30, 2023 | 09:35 AM
bcole's Avatar
bcole
Default Turboing my 2.0l
So I just picked up a 2.0L neon motor and wonder what head do I need to run to use to set up the turbo manifold that doesn’t use the srt4 head
Old Apr 7, 2023 | 06:56 PM
Nilo420's Avatar
Nilo420
I turboed mine. Running stock fuel injectors and pump, stock ECU. I also am keeping mine around 5psi of boost all I did was bolt on the turbo manifold and turbo then ran the oil feed and drain lines then hooked up the charge pipe and a good blow off valve and put a adjustable waste gate. Been running that setup on a auto transmission for a year now and no issues.the post is labelled p0335 bad crank sensor I have pics of what I did on that post
