P0455 (Large Evap leak)
Old May 8, 2023 | 02:40 PM
rwfnetworking's Avatar
rwfnetworking
Default P0455 (Large Evap leak)
Trying to track down a P0455 Large Evap leak. Hooked up my smoke machine and found a couple leaks but the P0455 still is coming back. I have the throttle body plugged, but I'm seeing a good amount of smoke from the butterfly pivot pin and also from the oil cap. Are these issues or normal areas that will leak during this type of test? I haven't tested the gas cap yet, but I hear that is a common cause of this error code.
Robert
Old May 12, 2023 | 03:08 PM
paw paw's Avatar
paw paw
^+1 on putting the gas cap, seal & neck sealing area, including the tank fill hose & its end connections on the suspect list. More thoughts for consideration, let us know what else you find.
