Blown head gasket or bad water pump?
Old Jul 18, 2023 | 05:17 PM
xanchoppa's Avatar
xanchoppa
Default Blown head gasket or bad water pump?
I bought a used 2003 dodge neon sxt the guy said he had smoke coming from the engine a couple months ago and took it in to get looked at they changed a cracked radiator and said the head gasket needed to be replaced. Now I was kinda hoping they were just trying to get one up on him or whatever and I don’t mind fixing the head gasket myself if I have to but if I don’t then cool. Here are the symptoms
-Boiling noise coming from the engine sometimes at idle but normally after I shut the car off
-Temp gauge fluctuates quickly up and down
-No hot air from the ac
-has only happened twice and I decided to let it it sit till I get it fixed after this but I stalled the car the other day turned it back on a puff of smoke or steam came out the engine bay and yesterday I shut it off it made a weird sound started boiling and I looked under the car and some fluid had spilled on the ground
anybody have an opinion as to if this might be the head gasket or the water pump?
Old Jul 19, 2023 | 05:26 PM
Nilo420's Avatar
Nilo420
I would order a head gasket set and a timing set with water pump.do both seeing how the water pump will be accessible when you do the head gasket.
Old Jul 20, 2023 | 11:20 AM
ol' grouch's Avatar
ol' grouch
Generally, you won't get hot air from the a/c unless it's broken. The 4 banger in the P cars is bad about blowing head gaskets. I'd replace the water pump and timing belt while you have the head off.
