viper brake setup on 2nd gen
Old Jan 12, 2006 | 05:49 PM
speedyrb29's Avatar
speedyrb29
Default viper brake setup on 2nd gen
dose any 1 know if this is possible i know there probly would be clarance issues with the caliper but im just woundering if you would have to get a new master cylender and stuff to?
Old Jan 12, 2006 | 06:12 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: viper brake setup on 2nd gen
yeah I'm sure its possible. Would it be worth it to do? Probably not. I would imagine you would need to replace pratically everything to put the brakes off the viper on a neon. Not worth the effort if you ask me. If you want bigger brakes why not use the ones off the SRT4, those would be at least a little better suited for the neon. You'll still be replacing a few parts.
Old Jan 12, 2006 | 10:29 PM
casper's Avatar
casper
Why? Its not gonna do you any good. The neon brakes are pretty good for the car. Unless you are gonna be doing excessive braking as in track racing, get some slotted rotors and good pads and you will be all set.
