Home Made Intake
Old Jan 15, 2006 | 09:42 PM
spikeymikey87's Avatar
spikeymikey87
Default Home Made Intake
hey i decided 2 cheep out on an intake and instead of going out and buying a short ram cuz i didnt want CAI cuz of snow and ****, i made my own. i didnt put in any piping or anything, because basically i have a K&N filter running off my throttle body. i did have 2 make a bracket to hold it up because if i didnt my throttle cable could fall off or something worse, but i was wondering what you guys thought of it
[IMG]local://upfiles/27482/DEE933F8366F4659A273D465D0D6DCC1.jpg[/IMG]
Old Jan 16, 2006 | 10:58 PM
joe2002dn's Avatar
joe2002dn
Default RE: Home Made Intake
u shold put the vavle cover breather on the actually valve cover the hose comes off if you pull hard enough and then there is a little nipple coming off the valve cover in the back and the left side, it looks a lot cleaner instead of being on a plastic hose
Old Jan 16, 2006 | 11:13 PM
spikeymikey87
yea i was going to do that but it didnt seem that there was a way 2 put the breather directly on the valve cover. that was actually the only thing that bothered me about the whole setup. thanks ill try doing that tomorrow
Old Jan 16, 2006 | 11:30 PM
neon2_0t's Avatar
neon2_0t
You can replace the piping after the throttle body with normal 3" intake tubing with like a 7" piece for like 12 dollars from any performance shop.
Old Jan 16, 2006 | 11:39 PM
spikeymikey87
do u mean 2 replace the rubber flexible pipe b4 the throttle body?
Old Jan 18, 2006 | 12:01 AM
neon2_0t's Avatar
neon2_0t
Yes....
Old Jan 18, 2006 | 01:41 AM
spikeymikey87
i would, but the wat i made the bracket 2 hold it up, there is a little bend in hte piping that would be 2 much of a pain 2 try 2 compensate
Old Jan 18, 2006 | 08:44 PM
LowSlowNeon's Avatar
LowSlowNeon
That looks almost exactly like my old setup. But I finally broke down not long ago and bought a K&N CAI...which seems to be much better then what I had before.
Old Jan 27, 2006 | 03:15 AM
neon2_0t's Avatar
neon2_0t
Yeah i sell intakes you can check them out if you want they are 3" fully polished. Comes with a bracket and everything you need for install...check um out at www.g-forceracingofmaine.com
