Adjustable Lowering Coilover Coil Springs Kit?
Old Jan 22, 2006 | 12:40 PM
Streetuner's Avatar
Streetuner
Default Adjustable Lowering Coilover Coil Springs Kit?
Hi, i am new to the dodge forum and the whole tuner culture. I have a base 2002 dodge neon which will be used for car shows and everyday travel (NO RACING FOR ME). As for now i have a very low front bumper and in fear of cracking it i have not lowered my car. However, i would like to be able to lower my car for shows and raise it back up for everyday travel. With this in mind I was just wondering if anyone is fimilar with HIPROSPEED Adjustable Lowering Coilover Coil Springs Kit (http://www.autogrimmig.com/-strse-29...-02/Detail.bok)? This particular kit is priced fairly low compare to other kits i have researched. So are they bad quality? Also, do Adjustable Lowering Coilover Coil Spring Kits come out of the box OEM height, and then are adjustable down from that? Or are the kits already at a low height and adjustable from that height?
Old Jan 22, 2006 | 09:52 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: Adjustable Lowering Coilover Coil Springs Kit?
if you want an easy way to raise and lower your car, think about air ride, then at the flick of a switch you can lift and lower your car fast, so then if you have to get into a driveway, or over road kill, ect, you can pick the car up to go over it and not worry about distroying your front bumper.....that is just an idea for you because coilovers are not easy to raise and lower, plus i have been to lots of car shows that have speed bumps in the entrence way that you could get over it easy with air ride suspension
