my cigarette light and my third lil brake light doesnt work?what should it be b4 i mess someone up.
im just gonne go through each fuse one at a time to see....make sure they all look cool. but besides the fuses if it could be something else. let me know. thanx alot... u guys got this site on lock...i really hope soon. to have some qt times..... soon. b4 and after i start my lil intake manifold and header rt switch over.....(((( can u guys help me more in this area...!!!!!.Preferably you'd want an RPM switch so the secondaries only open up at a certain RPM.!!!!!!!!!!!!!!! can u guys explain that to me........
Its probably a fuse. Pop the fuse panel off and look at the panel. It shows what fuses go with what electrical components on the car. Then check the fuses that may pertain to your problem. I'm pretty sure its a fuse. What caused it to quit working anyway? As to answer your R/T manifold question, I have not installed one but I've read that you do need a switch to activate the secondaries. Thats about all I know about that.
thanx... brakin light ended up/ kjust being the bulb... but i cant for the love of god find the.. or n e type of fuse that would indicate is the the inside cigerette light outlet..... can n e one helkp me out.. would it be in the inner door panel.. or the box under the hood... and what does it say... i figured it would say sometype of outlet.. or something....but it a whole loota car talk im unfamiliar with. even the guy at the auto parts store. could figuyre it out... thanx alot u guys.... and sorry for double messaging.... im still learning how to use the features of thise site... how can i erase the duplicated message. thanx
Hey guys i've found the solution to the cigarette ligher fuse situation..Its located on the fuse box under your hood. The fuse is called 20 AMP P/OUT. All you do is take that out, and get a new one from an auto store. (I got mines from Autozone) And just replace it into its correct slot. The one i bought is called "Smart Glow Fuse". It has a small tip that glows when the fuse is blown. But in any case, you should be able to match up the fuse just by its size and color. Its yellow with the number 20 on it. They are sold in packs of 2 and runs $3.24. So that's that. Let me know if ya have any questions.
thanx alot.. guys.. it worked. and yes the fuse was blown in the 20 amp fuse....... right on the money.. thanx guys. both probs fixed.. third light lookin bright as ever...and now i can hook up my gadgets inside the car.. thanx
