WHAT IS THE NAME AND NUMBER OF THIS PART? (PICTURE INSIDE)
Old Feb 14, 2006 | 09:22 PM
carlos_fb's Avatar
carlos_fb
Default WHAT IS THE NAME AND NUMBER OF THIS PART? (PICTURE INSIDE)
Hi, I have a 2002 Dodge Neon (the base one). I would like to know the name of the part highlighted in the picture attached and also the part number so i can buy it on local dealership.
Thanks
http://img142.imagevenue.com/img.php...58875_neon.jpg
Old Feb 14, 2006 | 11:06 PM
whyte69's Avatar
whyte69
Default RE: WHAT IS THE NAME AND NUMBER OF THIS PART? (PICTURE INSIDE)
I would simply walk into the dealership, tell them that you've got a 2002 Dodge Neon, Single Overhead Cam, 2 Litre engine, and you're looking for the corrugated breathing tube that comes after the throttle body, after the stock airbox.
This is a bit of a restriction for airflow. This can be fixed with an aftermarket Cold Air Intake, or even a small length of straight tubing.
What's wrong with the current one, that required you to replace it?
Old Feb 14, 2006 | 11:08 PM
03neonRT's Avatar
03neonRT
Huh my CAI didnt come with a raplacement tube for that...
Old Feb 14, 2006 | 11:40 PM
whyte69's Avatar
whyte69
some do, some don't. Check a few of the Neon galleries out and you'll see what I mean. I'm sure it wouldn't be hard to fabricate one out of some stainless steel tubing. Go to to a car parts place and some of them will have tubing that is designed for custom exhausts. Get a short length of straight tubing and pop it on there.
Old Feb 15, 2006 | 02:02 PM
nicks2kes's Avatar
nicks2kes
i have a stock one off my 2000 neon, i have it left over from the srt swap. pm for info/pics
Old Feb 15, 2006 | 10:51 PM
leadspud's Avatar
leadspud
The only problem with a riged tube would be that the engine moves around and the air box does not move, so something could brake. After time
Old Feb 16, 2006 | 01:39 AM
joe2002dn's Avatar
joe2002dn
its caled something like a bellows tube it expands and contracts when there is load on the engine. i heard that because of the ridges air goes into the ridges and robs the air from going directly into the intake manifold. the intaks that replace this tube typically claim more hp increase than and intake which keep this tube.
