Oil Light Comes On at Idle RPM
Hello all,
This is my first post, please does any one have answer for my symptoms:
While stopped at signal lights only some times the motor RPM drops lower than the idling RPM and the oil light comes on. (Neon 01)
A slight touch on the gas pedal brings the RPM up and the light goes out.
This happens not at all light stops. When all is ok the idling RPM seems to be normal.
Oil level is at full and new filter in last week (she did this with the old filter also)
[IMG]local://upfiles/32075/2CA1B290D618494D87979BBAFE8194CF.jpg[/IMG]
Not leaking oil? If oil level is full and everything is good there I would take aim at the oil pressure sensor cause that is what is tripping the oil light off. Maybe replace it? I don't know how much they run, but it shouldn't be that hard to replace yourself.
ORIGINAL: LowSlowNeon
Something on the throttle boddy perhaps? But even if the idle drops a bit it shouldn't be enough to trigger the oil pressure sender. The dummy light is set to go off when the oil pressure is rediculuously low.
1) Pulling spark plug wire did not help, the rpm dropped and vibration increased but no oil light.
2) Got a friend to connect his OBD II scanner and no codes active or present.
3) Found one sensor plug (The sensor above the oil switch) loose or almost out. Cold Idle rpm is much higher and reduces when the engine heats up.
4) To work at 6 am ambinet temp is low and fast commute no alarm. On way back at 3 pm ambinet day time temp (Vancouver) and lots of stop and
start at lights the oil light is back as before but the idle rpm seems not to drop as much.
5) Connected Radio shack batter/alternator tester all leds' upto 14.v led remais lit all time.
6) Have found tsb 18-017-01 REV.A Engine Idle Undersoot/Performance Repair Recommend to reprograme the PCM. All local delars have no appointment
avaliable till next week. (No upgrade Label in my vehicle for above)
Trending Topics
