starting the car
Old Mar 28, 2006 | 04:37 PM
nbowler2002's Avatar
nbowler2002
Default starting the car
Hello there. When I start my car it sometimes takes me about 5 or 6 times to start the car. It will not even turn over and just shut down. I have a five speed and having many problems with it. Please help if anyone has had the same problem.
Old Mar 28, 2006 | 05:01 PM
blank's Avatar
blank
Default RE: starting the car
i am having the problem right now. will it start then die or just not start? cause mine wont stay on
Old Mar 28, 2006 | 06:38 PM
nbowler2002
Mine will not stay on either. It acts as if the battery is dead. My car has only 4600 miles on it. I highly doubt that the battery is the issue.
Old Mar 29, 2006 | 05:43 PM
blank's Avatar
blank
i had the lid off of my air box then i put it on and it is fine now.
Old Mar 29, 2006 | 07:08 PM
nbowler2002
Hmm well its not all the time so I dont know that is really wierd and irritating for a brand new car having problems
Old Apr 2, 2006 | 04:10 AM
ewetho's Avatar
ewetho
Do not rule out a battery problem happens to them all. There are only 3 battery manufactueres for example Johson Controls makes die hard interstate motorcraft ect.... So Mopar does not make the battery. Plus if the car sat on the lot for a long time not uncommon for a poorly charged bettery to be a problem. If you jump a dead battey you cannot fully charge it with an alternator. Needs a proper charger. If you have a charger then try a trickle charge over night.
Could also be a problem wwitht he key not being icked up properly try the other key and see if that helps. You may need to visit DODGE.
Old Apr 2, 2006 | 06:19 AM
TJW815's Avatar
TJW815
sounds like a sentry key problem. does it start and die in 3 seconds? If it does your key needs programmed.
