Front Left Control Arm
Old Apr 7, 2006 | 04:20 AM
Webbie06's Avatar
Webbie06
Default Front Left Control Arm
Hey guyz, i have a 2004 SX 2.0, couple of days ago, while turning i hit the curb, Stupid me i know heh, so ended up i needed a new control arm, so i replaced my self, before i changed it the stearing was stiff, obviously cuz of the Control arm, now after replacing it, its still little stiff, Any ideas?
Thanx
Old Apr 8, 2006 | 07:48 AM
Webbie06's Avatar
Webbie06
Default RE: Front Left Control Arm
Hmm anyone? heh
Old Apr 9, 2006 | 02:24 AM
ewetho's Avatar
ewetho
Hard to say for sure but if your rack was extended on the side that was damaged you may have bent the rack and thus binding up. Also could be the strut mount at the top if the bearing is damaged.
Check your mounts by fealling it as someone turns it and see if you can feel the vibrations from it binding. Also bounce the affteded and non effected corners for the same thing. Hopefully you will find it there.
