Tachometer
Hello,
I'm a happy owner of a Dodge Neon SE 2005. I would love to have a tachometer installed but since I don't really know much about cars, I'm seeking help.
I found on the web that getting tachometer to work is as simple as splicing two cables together... but it sounds too simple... Could anyone summarize for me the installation process, or maybe point me to some website that has instructions?
Also, how acurate would an aftermarket tachometer be?
Thanks in advance!
Thanks in advance!
Trending Topics
not hard at all, just find a place to mount it and hook up four wires, as long as you get a tach with a two cylinder rating it is not hard at all, you can hook it right to the wire coming off of the coil for the rpm reading, and the positive and negitive, and the one for the light to light it at night not to bad at all accually nothing a pair of wire cutters, screw drivers and some soder and sodering iron can not do....about an hour max.....
good luck
ps it is alot eaiser to do if you have a tach with a two cylinder rating on it, if you get one with a 4 6 and 8 cylinder only it will only read at half of the real rpms, then you have to get a tach adapeter, i have one from sunpro and it works great!!!!
good luck
ORIGINAL: moobit
But what about the sxt clusters? which was my previous questions like three post's up there--^
