sound help
Old Apr 11, 2006 | 05:56 PM
senoner's Avatar
senoner
Default sound help
i installed two jl audio subs but recently they have been goin in and out. im not sure if its the ground wire or power problems. it doesnt go out for a long, for bout 10 seconds then come back. what should i check?
Old Apr 11, 2006 | 07:33 PM
ewetho's Avatar
ewetho
Default RE: sound help
All electricall connectors and that your amp fans are woorking. If you have an overheating issue the amps may turn off till cool. Depending on what you got! But check all lines to the unit.
