what size injectors
Old Apr 11, 2006 | 07:07 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default what size injectors
so i am almost getting ready to install my turbo kit, but i need to know what size fuel injectors to run, i am going to go with five lbs of boost what is a good size injectors to run with this set up any ideas, i can get them from the parts store that i work at but i need to know exactly what size to get.....thanks
Old Apr 12, 2006 | 01:37 AM
03neonRT's Avatar
03neonRT
Default RE: what size injectors
24lb should be more than enough if your only running low to medium boost...plus they come very cheap from MP...oh and you'll need to replace the oil pump and fuel pump also!
Old Apr 12, 2006 | 01:55 AM
lblackneon's Avatar
lblackneon
How about some pictures?
Old Apr 12, 2006 | 05:20 PM
Mike_02sxt's Avatar
Mike_02sxt
What size are the stock injectors, by the way?
Old Apr 12, 2006 | 05:45 PM
03neonRT's Avatar
03neonRT
ORIGINAL: Mike_02sxt
The stockers are 19lb i think...
Old Apr 12, 2006 | 10:31 PM
dtjackten's Avatar
dtjackten
on another forum i am on there was a guy who said 27 lb, is that to much for only 5 lbs, this is just to start buy the way i am going to build a bottom end so i can run up to 15 lbs, but 24 should be ok or am better off going 27?
Old Apr 13, 2006 | 02:07 AM
03neonRT's Avatar
03neonRT
Well on MP i think every size up to 36lb is the same price...so if your planing on running low boost for a long time then go for the 24's...but if you'll be running high boost relatively soon then you might as well buy the larger ones and save the money.
