torque for header bolts
Old Apr 15, 2006 | 12:50 AM
spikeymikey87's Avatar
spikeymikey87
Default torque for header bolts
hey i was wondering if there was a specific torque for the header bolts or should i just do them really tight
Old Apr 15, 2006 | 12:55 AM
neon2_0t's Avatar
neon2_0t
Default RE: torque for header bolts
probably 60-70 lbs not a heck of allot dont want to break the head off the bolt..... i've done it and its not fun to fix.
Old Apr 15, 2006 | 03:47 AM
casper's Avatar
casper
Tight.
Old Apr 16, 2006 | 03:55 PM
RadarLove's Avatar
RadarLove
NOT all that tight. 200 INCH-pounds, so 16.5ish ft-lbs. You'll strip that aluminum head a lot faster than you'll break the head off a steel bolt, trust me... Torque sequence is starting with the bottom center bolts, and working out from there. I usually make at least 3 passes to make sure it's the right torque all the way across, then go back and check it after a day or two of driving.
Heat shield bolts are 95 IN-lbs. The flange bolts (exhaust piping) are 250 IN-lbs. For the manifold support bracket... the horizontal bolt (M10) is 40 ft-lbs, the vertical bolt (M12) is 70 ft-lbs.
Best of luck!
Old Apr 16, 2006 | 04:46 PM
Mike_02sxt's Avatar
Mike_02sxt
I hope you have a torque wrench...
Old Apr 16, 2006 | 10:10 PM
spikeymikey87
i can get one easy from my school
