roll cage?
Old Apr 21, 2006 | 03:35 PM
Freerider's Avatar
Freerider
Default RE: roll cage?
I saw one a long Time Ago. Ill do some research tonight but they might, i say again might, have one on Howell Automotive. I will do more research when I get home. So count on a response later tonight.
Old Apr 21, 2006 | 04:20 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
probly about 30-40 dollars plus shipping
Old Apr 21, 2006 | 06:53 PM
NonToxic's Avatar
NonToxic
so if i were to get a car which of these 2 spots would i hook it up at?
do ihook it up like right next to where you hook up your trunk strut bars? like in this picture
or do i hoook it up here? like at the top where the the seal belt anchors are at the top?
and if i hook it up to either one where should i run the harness to because i have a harness that needs to connect to a bolt....
Old Apr 22, 2006 | 01:29 AM
dtjackten's Avatar
dtjackten
are you trying to put in the harness in the front or rear of the car? i was thinking you where putting them in the front of the car and that would be where the front door latches and the rear door hinge hooks to, but there is a panel that you can take off and weld to that pillar just behind the front seats....... you might have to get the pipe bent alittle bit but you can get that done at about any custom pipe bending shop,
