SRT4 struts
No it wont raise or lower, the ride height should be exactly the same but with the struts you'll be able to get wider tires!!! So if your going to get SRT struts you might as well by some nice Eibachs and do everything at once..
so does that mean that if you use srt struts with eibach proline (1.5 in drop) the struts will last longer than the stock sxt struts with those springs or is it maybe completely safe with them
the only broplem is it would raise your car almost back too stock height. I know this because I put srt struts on one of my buddy's cars and he had prolines and it raised him almost back too stock. But the drop with sportlines + srtstruts look pretty nice
but then how can you put srt struts and springs on a car, which doesnt change the ride height, and then put lowering springs on it and it stays the same height?
Trending Topics
Its a bit of an overstatement. Stock SRT springs/struts may increase your ride height like .25"-.50" but no more than that. So when you put the proline springs on it wont lower it as much, but they will still lower the car an inch- 1.25".
(oh and post #500 right here!!!)
ok perces on struts is 3/4 higher and also the srt is a weighs more the our car so when you put proline on a actaul srt it will be lowered because of the extra weight
I promise you guys that with prolines you are gonna be about stock height or maybe a 1/2 lower then stock but no one will notice your drop no more. I am speaking from expierence.
okay for my 01 neon..i got the srt4 wheels... and i needed the struts... so i put the srt struts and tires on and it raised my car about 1 inch or a little more.. but then i put on the srt springs and it lowered it to stock srt height
