major problem
Old May 2, 2006 | 03:17 PM
ACD06's Avatar
ACD06
Default major problem
I have a 01 Neon with 71,000 miles. Over the weekend the gas pedal went to the floor, the dash lit up and it hasnt started back up. It been to 2 dealerships now and they cant figure out whats wrong with it. Any ideas?
Old May 2, 2006 | 07:21 PM
Topher's Avatar
Topher
Default RE: major problem
??? thats a tough one. I would first try replacing the entire ETC since you said the pedal went all the way to the floor. The dash lighting up and the car not starting could be a side of affect of a failure of it.
Old May 5, 2006 | 04:13 PM
ACD06's Avatar
ACD06
well i finally got an update it only took them 5 days to figure out it was the powertrian control module. figures. but luckly its still under warranty.
Old May 8, 2006 | 05:45 PM
ACD06's Avatar
ACD06
OMG the PCM was not the problem. I got a call after my car has been at the shop for over a week now that the PCM was installed yet the car wont start. Now they say they have to check all the cicuits. Has anyone else ever had a problem like this. Cause according to the mechanic he's never seen this before and is playing everything by ear. Thanks
Old May 8, 2006 | 05:52 PM
casper's Avatar
casper
Sounds interesting, I have no clue
Old May 9, 2006 | 07:15 PM
MIKESERSPECV14.8's Avatar
MIKESERSPECV14.8
ORIGINAL: ACD06
THATS WHAT YOU GET FOR BUYING A CHEAP PIECE OF AMERICAN ****.
GET A CAR THAT WILL LAST PAST 71,000 MILES. DOMESTICS BLOW ***.
IF DEALERSHIPS CANT FIGURE IT OUT YOU BETTER JUST PUSH IT OFF A CLIFF, WHICH YOU SHOULD HAVE DONE WITH YOU IN IT WHEN YOU BOUGHT THE PIECE OF ****.
Old May 10, 2006 | 02:13 PM
ACD06's Avatar
ACD06
well now i'm told its the crankshaft sensor, and another sensor thats gonna run me about $400. After almost 2 weeks I'm glad it isnt worse. But we'll see if there right.
Old May 10, 2006 | 05:03 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: MIKESERSPECV14.8
ORIGINAL: ACD06
thanks... im sure this will help greatly
besides, if i recall correctly the 2.0 was actually made by mitsubishi???
