Ignition Coil from Screamin Demon
Old May 8, 2006 | 01:30 PM
lblackneon's Avatar
lblackneon
Default Ignition Coil from Screamin Demon
Should I get the igniton coil from Screamin Demon? If I get that, I'll most likely get the Crane wires and Accel spark plugs? My coil is fine but I would be doing this to help my performance.
http://www.howellautomotive.com/inde...ROD&ProdID=250
Here are my mods along with the ones in the signature:
Perform. mods: AFX Race PCM, AEM CAI, Pacesetter Header & C-back, AFX Underdrive Pulley, 60mm MPx Throttle Body, Prothane Motor M. Inserts, Accel 19lb Fuel inj., Vibrant front strut tower bar, Progress Rear Sway Bar, B. bushings
Old May 8, 2006 | 03:43 PM
casper's Avatar
casper
Default RE: Ignition Coil from Screamin Demon
You probally won't notice the difference in performance. IF I remember right the screamin demon is a little better than stock, but not by much
Old May 10, 2006 | 03:21 PM
asanti's Avatar
asanti
The SD coil isn't bad at all. I've noticed a much better throttle response in my ride and have had it in for roughly 25K miles. The only thing you have to be mindful of is that with the hotter spark the SD coil gives, you need to gap your plugs from at LEAST .045 to their recommended .065. It's not a bad investment overall.
Later
Allex
Old May 11, 2006 | 12:46 AM
Mike_02sxt's Avatar
Mike_02sxt
I believe the factory gap is .35, is it not?
Old May 11, 2006 | 01:30 AM
ewetho's Avatar
ewetho
Factory gap is .035" and yes those screamin demon guys ask for .065" so with new plugs and good wires you should be able to get the larger gap. If fired correctly can burn the A/F mix better and more completely thus giving a touch of power as well as lower emissions. Theoretically.
He was comfortable trying .045 and found it works good for him.
