check engine light question
Old May 11, 2006 | 04:59 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default check engine light question
so as my other posts has said i am putting a turbo on my car, not the next Q i have is the check engine light going to kick on when the turbo is put on, if so is there a way to bypass it or override it, i know they make a diode that goes in like mustangs and other muscle cars but do they make them for a neon????????????????
Old May 11, 2006 | 04:30 PM
tooslow's Avatar
tooslow
Default RE: check engine light question
you should not get a check engine light if you do it right it the only thing you might need is some sort of map clamp or voltage clamp so the map senser does not see boost. My car is boosted and the only codes are oil senser code because I was too lazy too tee oil senser in.
btw what are you doing for feul
