Trouble code 1495
Old Jun 7, 2006 | 01:31 PM
chris3829's Avatar
chris3829
Default Trouble code 1495
Anyone know where the "LDP" leak detection pump soleniod circuit is located??? Is it on the tranny??...I'm getting code 1495...It's an 01 NEON ES 2.0liter. Any help would be appreciated.
Old Jun 9, 2006 | 03:44 AM
ewetho's Avatar
ewetho
Default RE: Trouble code 1495
Sounds like evaporative emissions gear.
Old Jun 10, 2006 | 02:53 AM
1996squishysohc's Avatar
1996squishysohc
that is a code for the leak detection pump for the evaproative emissions system. the first thing you need to check is the lines and hoses that the system uses. Check all vaccum lines in the engine compartment and any rubber hoses underneath the car. If you see any that are cracked or completely split, replace them. the leak detection pump is located underneath the car by the rear suspension. Ususally when this code comes up the LDP must be replace, or there is a significant vaccum leak in the system. I attached the instructions that chrysler gives to remove the LDP. If you need anymore help please write back or email me.
REMOVAL
Raise and support vehicle on a hoist.
Push locking tab on electrical connector to unlock and remove connector.
loosen the sway bar bracket to remove the pump bracket.
Remove pump and bracket as an assembly.
Disconnect lines from LDP.
Remove filter.
Remove pump from bracket
Old Jun 13, 2006 | 01:39 PM
chris3829's Avatar
chris3829
Thanks a million 1996
