Need Help guys!
Old Jun 12, 2006 | 11:46 AM
marriner's Avatar
marriner
Default Need Help guys!
I am trying order MSD Spark plug wires from a local dealer (because I am in Canada). I have a 2004 Dodge SX 2.0 ( canadian for neon) and the dealer is telling me that MSD does not make a wire for a 2004 2.0L Neon. Now I know this must not be true, so I need a MSD Part number for a wire that would be compatible with my 2004 2.0L Neon. Or Even a Part # for compatible Magnecore wires would be helpful.
any help would be greatly appreciated.
I should also mention that they previously sold me SRT-4 Wires that were too short and had to return them.
Thank you!!
Marriner
Old Jun 12, 2006 | 11:54 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Need Help guys!
In this link http://www.msdignition.com/wire_sets_1.htm#chryser, the newest vehicles they went to was 2000. Is your motor similar to a 2000 Plymouth (only one they listed) Neon? Check it out, it's almost to the bottom.
Anything wrong with ACCEL wires?
Old Jun 12, 2006 | 12:20 PM
marriner's Avatar
marriner
I'm not too sure if the motor would be the same as a 2000? Is there any way to find out?
I haven't heard too much conversation about ACCEL wires, are they any good?
Thanks,
Old Jun 12, 2006 | 12:23 PM
silvercoupe97
Uber Moderator
Accel is used all the time. I believe the MSD has a lower ohm rating though, but I personally don't think that it's low enough to even notice. I'll stick with 8mm-10mm Accel wires. I don't know if the motor changed from 2000 to 04 to be honest with you.
Old Jun 12, 2006 | 02:11 PM
Freerider's Avatar
Freerider
the 2000 + all have similar if not the same motor. Both are the 2.0 liter, 16v SOHC engine. It is the body style that changed over the years.
However, im not sure if the SXT and the SX 2.0 are the same but modern performance and howell sell MSD wires and ignition coils, fuel pumps, etc.
Old Jun 12, 2006 | 08:43 PM
Acrfanatic's Avatar
Acrfanatic
http://www.car-stuff.com/performance...me=4&category= TRY THIS SIGHT
Old Jun 12, 2006 | 08:51 PM
silvercoupe97
Uber Moderator
ORIGINAL: Acrfanatic
Good site. They have my plug wires there at even less than other vendors I normally frequent.
Old Jun 13, 2006 | 09:48 AM
marriner's Avatar
marriner
Hey thanks for the site! The prices look good, but unfortunatly the wires were for a 2.4L. not a 2.0.
I ordered a set of MSD # 32729.
They aren't listed on MSD's site for a 2004, but they are listed for a 2.0L 16v. SOHC
Thanks for all your help guys. I'll let you know what happens.
Cheers,
Marriner
Old Jun 15, 2006 | 09:52 AM
marriner's Avatar
marriner
Hey all.
I received the set of MSD # 32729 yesterday for my 04 Neon and Thankfully they fit!
Thanks for all your help with this.
Cheers,
Jesse
