how can i get my acceleration better
Old Jun 20, 2006 | 10:35 AM
Acrfanatic's Avatar
Acrfanatic
Default how can i get my acceleration better
I know there is a forum of "how to make my 2nd gen neon faster " but i purely want acceleration. HOw can i make my acceleration better without spending over 200 dollars? Thanks
Old Jun 20, 2006 | 03:31 PM
lblackneon's Avatar
lblackneon
Default RE: how can i get my acceleration better
It's pretty simple; POWER EQUALS MONEY.
200 dollars? Good luck. For that I'd buy an intake or header but it wont do much at all.
Old Jun 20, 2006 | 03:51 PM
Freerider's Avatar
Freerider
+1
You'll see better accelleration and better power with the more money you put into your car. 200 dollars will give you nothing power wise. It will get you either a header that needs a port-match, or an intake. Either one will give you better performance over stock.
For the most bang for your buck for accelleration, i guess i would recommend a budget for about 2,000 bucks, and getting:
Intake
Exhuast
Header
TB
PCM (which i have no idea if it works. Conflicting stories. Up to you)
after you get more air into your engine you'll be running a lot faster.
Old Jun 21, 2006 | 02:08 AM
ewetho's Avatar
ewetho
Judging from you listed MODS I would have to say Prothane Race Motor Mount Inserts and Vitor's Trans Mount Inserts this should help you launch harder. Then if wheel hop is still evident a urethane bushing kit.
Old Jun 21, 2006 | 10:19 AM
Acrfanatic's Avatar
Acrfanatic
where can i find these inserts?
Old Jun 21, 2006 | 04:03 PM
lblackneon's Avatar
lblackneon
ORIGINAL: Freerider
Intake
Exhuast
Header
TB
I have those and I still wasn't satisfied; that's why I'm doing what I'm doing to my car. Since u have a 2002 u could prob get the AFX PCM. It's pretty cool but like I said, I still wasn't satisfied. I'll hopefully get my car back by the end of this week and I'm going to see how it runs then[sm=gears.gif].
Old Jun 21, 2006 | 04:08 PM
lblackneon's Avatar
lblackneon
BTW; u can find inserts at Howell automotive or Modern performance. Compare prices.
Old Jun 21, 2006 | 05:12 PM
03neonRT's Avatar
03neonRT
Well I dont think its possible to be "satisfied" with acceleration on a N/A Neon...and if your budgeting $2,000 for mods (as Freerider suggested), you can get a complete SRT turbo setup and run 6-8psi for that price, and then you'll be satisfied with your acceleration! (at least until you want to run 12-15 and have to build it up)
