!!URGENT! 2002 Neon Tranny Problems!!!
Old Jul 10, 2006 | 04:33 PM
MrPotus's Avatar
MrPotus
Default !!URGENT! 2002 Neon Tranny Problems!!!
I was driving today and i was headed downhill when my 2002 Neon SXT shifted into first suddenly (AT). its been in 1st gear ever since. All the fluids are ok, and they're are no leaks.
A few months ago however the radiator broke and mixed the coolant and ATF. The radiator was replaced and the tranny was flushed numerous times, and it was fine for several months with no problems, until today when it got stuck, I can floor the gas but no change, only the rpms go through the roof... any answers???
I have a code p0700 which means something greek, anyone know where i should start?
Old Jul 11, 2006 | 12:14 AM
neon2_0t's Avatar
neon2_0t
Default RE: 2002 Neon Tranny Problems
try putting it back manualy
Old Jul 11, 2006 | 12:52 PM
MrPotus's Avatar
MrPotus
Is there any chance it could be something called a shift solenoid body, but i think it may be the module on the side of the transmission??? Any other guesses?
Old Jul 11, 2006 | 12:57 PM
MrPotus's Avatar
MrPotus
I also still have reverse. I've been driving it around and its fine, minus the fact it wont go beyond first.
Old Jul 11, 2006 | 03:51 PM
NHARINTON's Avatar
NHARINTON
i had that code and p0500 p0500 was the speed sensor. When i had that fixed and the codes cleared, i was good to go. I had the exact problem you are having. Any warrenty??
Old Jul 11, 2006 | 05:03 PM
MrPotus's Avatar
MrPotus
Warranty went out last year on the damn thing. the only code I have is the p0700 for the Transmission control system malfunction(EATX). Its gonna cost 266 to get a new module and i can't return it if thats not it. And shifting manually does nothing. Anyone have any ideas before I donate some money to the local Dodge Garage?
Old Jul 11, 2006 | 05:21 PM
NHARINTON's Avatar
NHARINTON
Stupid ised but have you gotten under the hood and made sure the shift lever on the tranny is not jammed up??
it should be right under ypur airbox??? just an idea!
Old Jul 12, 2006 | 01:59 PM
MrPotus's Avatar
MrPotus
The shift lever isnt jamed, it will move into every gear just no response from the tranny.
Old Jul 12, 2006 | 03:38 PM
NHARINTON's Avatar
NHARINTON
WOW, thats no fun, i would say take it to a tranny shop also and get two opinions. Also most transmission shops will guarantee thier work, so if they tell you its on thing and its not you wont have to pay full price.
Good Luck with getting it fixed!!
Old Jul 15, 2006 | 04:32 PM
Bunta Fujiwara's Avatar
Bunta Fujiwara
WOW!!!!!!! Good luck guy!!!
