I can't fit 17's on my 05 SXT...WTF?
Old Jul 10, 2006 | 04:57 PM
ability2005's Avatar
ability2005
Default I can't fit 17's on my 05 SXT...WTF?
I went today and had some 17's test fitted on the rear of my Neon 05 SXT. They showed me that the wheels will rub against a suspension part. That's without a tire even beng on there. i need to know how to get the 17's to fit on the rear without rubbing against what looks to be a suspension bar/sway bar at the rear wheels.
Old Jul 10, 2006 | 05:10 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: I can't fit 17's on my 05 SXT...WTF?
ORIGINAL: ability2005
The problem is wheel offset and you'll need to use spacers. Depending on the wheel's offset....it may be sitting too close to the inside of suspension. You need a wheel that's more opened and further away from the suspension.
MidnightBlueNeon has 17's on his Neon....but his is older....2002-03 I think...
Old Jul 10, 2006 | 07:01 PM
ability2005
Do you know what size spacers I need.... i see some that are 25mm 30mm 5mm 10mm 15mm. I honestly have the slightest clue. I believe 25 would be plenty but i am looking for a second opinion. thanks
Old Jul 10, 2006 | 09:50 PM
neon2_0t's Avatar
neon2_0t
Also if you upgrade the suspision with coilovers, i have coilovers from image performance thats are 36 way adjustable and with them you can fit almost any rim you want in the fender ive seen people put 19's in before.
Old Jul 11, 2006 | 10:13 AM
Midnight SRT's Avatar
Midnight SRT
Nightly Creeper
A stock 2nd gen Neon will only fit up to 18's (with 35 profile tires), 17's with 40 or 35 profile tires... I've had both 18's with 35's and (now) 17's with 40 profile tires...
If it is spacers that you need. I would need to know the offset and width of the wheels... to let you know what size spacers you need...
Old Jul 11, 2006 | 11:52 AM
LowSlowNeon's Avatar
LowSlowNeon
I have 17s on mine as well. Mine fit just fine with no problems. My offset is 42, if that helps you out at all.
Old Jul 11, 2006 | 07:09 PM
hlfbck20's Avatar
hlfbck20
i have an '01 with 17's and i didn't put any spacers on mine at all... could it be the type of rim that your getting...
Old Jul 12, 2006 | 06:34 AM
03blacksxt's Avatar
03blacksxt
Well this post kind've concerns me, because I have a 2003 SXT and I'm looking at some 17"x7" with a +40mm offset. I'm also planning a 1.4" drop. Does this sound like I will have a problem with rubbing and such? What size tires do you reccomend I get?
Old Jul 13, 2006 | 05:18 AM
hlfbck20's Avatar
hlfbck20
there might be.. but it kinda depends on what size tire you get.. and you can get 7.5 on there if you wanted... but correct me if im wrong .. the bottom of the perches are stationary and it's just the springs that move, so when you lower it the perches should be fine..... unless they get changed during the process, that i'm not too sure of
Old Jul 13, 2006 | 01:31 PM
twk62390's Avatar
twk62390
I have a 05 sxt and i put 17x7 with a 40mm offset and i needed spacers, i believe 15 mm. just thought i would bring this up, not really sure if it helps or not.
