trans mount insert question
Old Jul 16, 2006 | 05:12 PM
spikeymikey87's Avatar
spikeymikey87
Default trans mount insert question
i just got my trans mount inserts from vitor but im just not sure why there are 2 inserts. are there 2 mounts or do they both go into the same mount. idrather find this out b4 i try putting them in because it looks like a pain in the ***
Old Jul 16, 2006 | 06:27 PM
ewetho's Avatar
ewetho
Default RE: trans mount insert question
They both go in in the same mount one on each side and by design of the chassis side mount bracket nothing is required to hold them in. Tose part numbers and pentastar on them will look real familiar when you get the Trans mount off. Yup molded from an actual mount. Not bad just a bit more work than engine side. Found it to also actually lower felt vibration of my race mounts. Any question just PM me and will see what I can do.
Old Jul 16, 2006 | 08:52 PM
spikeymikey87
ok thanks a lot thats wat i thought you did ill prob put them in some time this week im tryin to get the vibration from race mounts away too
Old Jul 17, 2006 | 02:07 AM
ewetho's Avatar
ewetho
Wont eliminate them but recduce the bigger stuff is what I have found.
Old Jul 18, 2006 | 01:12 AM
leadspud's Avatar
leadspud
Where can I find these viter trans mount inserts?
Old Jul 18, 2006 | 02:16 AM
spikeymikey87
www.neongoodies.com
$37.99
Old Jul 18, 2006 | 10:07 PM
spikeymikey87
well i put it in and i maybe i did something wrong but it now has harsh vibrations at a higher rpm lol o well it took me 4 and a half hours and im def not taking them out
