program a new keyless entry
Old Jul 20, 2006 | 02:17 AM
luckiec7's Avatar
luckiec7
Default program a new keyless entry
I bought my 2000 Neon used and I'm pretty sure it has the keyless entry option, but it didn't I don't have the remotes. My brother works at a dealership and gave me a generic one, but I can't get it to program. I did what it said in the manual and it didn't work. Does it have to be a Dodge Neon remote to program or can I use the one he gave me? And if I can use this one is there a special way I have to program it? Thanks!
Old Apr 10, 2007 | 03:07 AM
dragondude09's Avatar
dragondude09
Default RE: program a new keyless entry
it needs to be a remote that has the correct MODEL/FCC ID and F/N numbers
Old Apr 10, 2007 | 03:15 AM
03neonRT's Avatar
03neonRT
ORIGINAL: luckiec7
So your Neon came with keyless entry, but you dont have the orignal remotes. And your brother at a dealership gave you a blank keyless entry key fob correct?
The only way for you to program a new transmitter is to already have one transmitter programmed on the system, otherwise, you need to take it to a dealer and have them program the first with a DRBIII.
Lol I just noticed the original post date... Oh well, someone should find this useful at some point...
Old Apr 10, 2007 | 12:41 PM
Andpto's Avatar
Andpto
well i found it useful cause i have the same problem it has keyless entry but i dont have the remotes. Can Ibuy one of those remotes from ebay that are from dodge and get it programed at the dealership. How much would it cost me?
Old Apr 11, 2007 | 01:08 AM
snare_samn's Avatar
snare_samn
Can you still program this work if the car didn't originally come with the keyless entry option?
Old Apr 11, 2007 | 06:59 AM
03neonRT's Avatar
03neonRT
ORIGINAL: snare_samn
You would have to get the first key programmed by a dealer using a DRBIII, but then you could add two additional remotes with this method.
