brake lights out on 2000 neon
Old Jul 24, 2006 | 06:06 PM
usirchchris's Avatar
usirchchris
Default brake lights out on 2000 neon
I have a 2000 neon that had all of the brake lights go out at once. All three brake lights are out. I have pulled all of the fuses, and have checked the bulbs, by visual only. Not sure what the problem might be...any ideas?
Old Jul 25, 2006 | 03:00 AM
Bunta Fujiwara's Avatar
Bunta Fujiwara
Default RE: brake lights out on 2000 neon
Something could have overloaded the cuircut. Have you had ANYTHING done to the electrical system? Sound system, anything? Or simply, a wire in the cuircut could have its wire exposed and is grounding out on the body someplace.
Buy a voltmeter and check the voltage with lights on, and check resistance with power off.
I don't think there is a major problem with Neons for this, so it's something small that im sure you can find buy testing the cuircut, fuses, and any relays.
