Taking Lettering Off Trunk??
Old Jul 26, 2006 | 05:47 PM
mike9fore's Avatar
mike9fore
Default Taking Lettering Off Trunk??
I am a Newby!! I need help in takling Off the Neon and Dodge lettering off the trunk....Can I get some help!!
Thanks
Old Jul 26, 2006 | 08:01 PM
NHARINTON's Avatar
NHARINTON
Default RE: Taking Lettering Off Trunk??
razor blade and goo-gone. Be carefull not to scrach the paint. i just did mine it took 5 min.
Old Jul 31, 2006 | 02:10 AM
NeonIllusion's Avatar
NeonIllusion
NNOOOO Razor blades!!
Get yourself a heatgun (or a decent Hairdryer), a pair of mechanic gloves(or similar), and some goo-gone or bug and tar remover(bug and tar works great, almost no rubbing at all)
Heat up those decals and get em good and hot they will peal right off, the gloves are so you don't burn your fingers, peel slow and work your way up the letters as you peel them off as to not break them.
If thier is any residue left use the bug&tar remover to take it off.
When you're done, you should wash your car (or at least the trunk) with some dishwashing liquid to remove the wax, and re-apply a good coat of wax.
Old Jul 31, 2006 | 02:31 AM
03neonRT's Avatar
03neonRT
ORIGINAL: NeonIllusion
Couldnt have said it better myself, but instead of a razor blade you can either use floss or a plastic putty knife if your having trouble getting them off...
Old Aug 1, 2006 | 07:22 PM
SvPir8's Avatar
SvPir8
I actually did it just a few days ago... and I guess it was still hot enough out i just peeled it off w/ my finger nail and it barely left any glue. Whatever glue was left I just picked it right off.
Now ... I still have to wax the car to remove any trace of the lettering and I suggest doing the same
