Hooking up a Tach...
Old Jul 26, 2006 | 11:50 PM
camlen1098's Avatar
camlen1098
Default Hooking up a Tach...
Ok, I want to buy this guage pod along with a tach for my '03 SE but I don't really have any idea how to incorporate the tach in.....so does anyone know how to hook one up?
THe Tach:
- MOPAR Logo 2 1/16 In-Dash Tach 8,000 RPM
Color: White
Style: MOPAR
Part #: MOPP4510428
Cost: $115.99
Old Jul 27, 2006 | 01:06 AM
NHARINTON's Avatar
NHARINTON
Default RE: Hooking up a Tach...
You will need a tach adapter. Automeeter part #1695. I got mine on ebay for like 20 bucks.
Old Jul 27, 2006 | 02:16 AM
camlen1098's Avatar
camlen1098
ORIGINAL: NHARINTON
Okay I just looked on ebay and other sites even and could not find any autometer anything with that part number..... Would the PN: Automter 9117 work as well? and even if I do get one how do you hook it up and such? and will it work with Mopar guages?
Old Jul 27, 2006 | 05:40 AM
NHARINTON's Avatar
NHARINTON
Yeah that is it, the 1695 was another company, i looked at mine it is 9117. It is really easy to hook up.
the wires on the 9117:
• Red & Red w/ Green stripe = wired in-line on ignition coil power supply that powers all coils. Installation varies widely from vehicle to vehicle.
• Black = common chassis ground
• Gray = tachometer signal output, connect to Green wire on tachometer
install Instructions:
Locate the dark green wire with an orange stripe and cut it in half. Wire the adapter between the two cut halves. Then the grey to the green tach wire. THEN the power. and you are done!!
It aslo has fault protection. If installed wrong it will not hert it. Mine did not work first try and i had to switch the red, and red w/green around. (input/output)
Old Aug 1, 2006 | 03:32 AM
makenax's Avatar
makenax
ok one quick question. if my car's got no factory tach, can i hook one up? and how
Old Aug 1, 2006 | 03:43 AM
camlen1098's Avatar
camlen1098
ORIGINAL: makenax
My car has no tach either, that is why I am putting this tach into it.....so to answer your question "yes, you can hook one up in your car, and how....just the way they explained above"
Old Aug 1, 2006 | 07:14 PM
airborne0801's Avatar
airborne0801
Is the info you gave true for all years? I have a 2000 and I am trying to hook up a sunpro protach II. My car did not come with a tach does anyone know if this will require an adaptor and were you can get one.
Old Aug 7, 2006 | 01:16 AM
NHARINTON's Avatar
NHARINTON
if it has DIS ignition (no distrubuter) just the box on your valve cover it will have to have the adapter. It should be the same one as above.
Old Aug 14, 2006 | 12:31 AM
lost cuda's Avatar
lost cuda
i know i need a tach adapter. however i have a tach that i like but it is foriegn. will it work with the autometer tach adapter or should i buy a better gauge?
Old Aug 15, 2006 | 12:16 AM
NHARINTON's Avatar
NHARINTON
Not sure about a forigen tach but i would think it should be the same, just call the company that makes it, if you dont have the number just search it and i am sure you can find it.
