injectors
Old Jul 28, 2006 | 02:44 AM
spikeymikey87's Avatar
spikeymikey87
Default injectors
what is the stock size injectors on an 04 sxt and what would be a good price for srt-4 stage 1 injectors because i might be able to get some for a good price
Old Jul 28, 2006 | 02:54 AM
ewetho's Avatar
ewetho
Default RE: injectors
If memory recall most attribute them to be about 19 Lbs. SRT and SRT stage 1 injectors would both be bigger. Now to have any advantage you need to be able to use the extra fuel or you will lose milage and performace both for NO gain. Friend had a highly modded Acura that had 27 lbs injectors and when tuning on the dyno finally changed them back to 24 lbs and gained 15 HP and an idle sustainable under 1000 RPM. Bigger is no better always. Sometims you loose. So without a Port and Polished head, nasty Cams etc. No point.
Old Jul 28, 2006 | 02:56 AM
spikeymikey87
ino i wouldnt just put them in by themselves but i might be able to get a good price so i can use them along the way possible turbo or sell them for more
