bottom end with a turbo
Old Aug 4, 2006 | 04:58 PM
  #21
spikeymikey87's Avatar
spikeymikey87
Default RE: bottom end with a turbo
ok so i would have to get a manual transmission, a new computer to run it, shifter cables shifter(short throw), and a strong clutch what is a good brand of a strong clutch and what kind do you sugggest
Old Aug 4, 2006 | 05:56 PM
  #22
03neonRT's Avatar
03neonRT
ORIGINAL: spikeymikey87
Clutchmaster makes awesome clutches, but you only need that if your doing the bottom end rebuild, ortherwise just go with the PT non-turbo clutch...the whole MTx swap is a bit more involved than just getting a tranny, you'll also need the PCM out of a MTx of your year Neon, along with a bunch of other things like new pedal assemblies, clutchmaster cylinder, and a bunch of other things...
Old Aug 4, 2006 | 06:01 PM
  #23
spikeymikey87
would a srt trans bold up correctly?
Old Aug 4, 2006 | 07:15 PM
  #24
03neonRT's Avatar
03neonRT
Well the 2.0 and 2.4 blocks are very similar, and the tranny will physically bolt onto the block, but to make it operational it wont just "bolt up"...the 2.0 uses a T350 transmission while the SRT-4 uses a T850...in order for the T850 to fit properly on the 2.0 you will need to replace the stock tranny mount, axles (because the 2.0 uses small different sized, skinny axles, while the SRT uses thicker, stronger axles and a LSD), brakes, and hub assemblies with ones off of a SRT-4.
Old Aug 4, 2006 | 10:07 PM
  #25
tooslow's Avatar
tooslow
the srt tranny will not fit on 2.0 sorry
Old Aug 5, 2006 | 03:05 AM
  #26
spikeymikey87
well that sux o i guess ill have to look for a t350 trans are all 5 speeds the t350 or are there different kinds
Old Aug 5, 2006 | 07:47 PM
  #27
03neonRT's Avatar
03neonRT
There are different gear ratios, the R/T has 3.94 final drive while the base Neons have the 3.55.
Old Aug 12, 2006 | 03:14 PM
  #28
spikeymikey87
which would be better to get or does it matter?
Old Aug 12, 2006 | 03:44 PM
  #29
03neonRT's Avatar
03neonRT
For N/A the 3.94 are awesome, but for turbo, not really sure, but probably the 3.55's because you would not go through the gears as quickly...besides it would be way easier to find a 3.55 tranny than an ACR-R/T tranny.
Old Aug 13, 2006 | 02:57 AM
  #30
spikeymikey87
ok thanks ill have to keep an eye out for all of this stuff now
