NEED HELP! Shifter Cable Bushings
Old Aug 19, 2006 | 02:48 PM
trllrneon's Avatar
trllrneon
Default NEED HELP! Shifter Cable Bushings
My son's car is a 2001 Neon RT, 5 speed. The shift cable bushing on the transmission side wore out and this is not a serviceable item from Dodge. I've tried junk yards, no one seems to have this nor do they want to sell this separate from the whole package. Where can I find replacement parts NEW or Used for this!! Need Help, would appreciate some feedback. Thanks in advance.[&:]
Old Aug 19, 2006 | 04:17 PM
03neonRT's Avatar
03neonRT
Default RE: NEED HELP! Shifter Cable Bushings
Modern Performance sells the replacement bushings in a 4pc. set for the transmission side and shift cable side...
http://www.modernperformance.com/dcx/booger.shtml
Old Aug 19, 2006 | 08:44 PM
01 r/t's Avatar
01 r/t
im wondering if im developing this problem because i am starting to feel a notch between shifts every once in a while that i know wasnt there before. I know its not the synchros because its not grinding its just a little notch every once in awhile. Please let me know if im experinceing my bushings going bad. Because this is my first manual car and i am a decent shifter i think. When i coast i never ride the gears if im going slow and i usually **** at the 3600 rpm mark. I have felt this shifing into second forth and reverse.
Old Aug 20, 2006 | 04:09 AM
ewetho's Avatar
ewetho
I have bushing and feel a little notchyness in 3rd. Cables are not very positive and while the BoogerBushings are the greatest thing since sliced bread for a Neon not a total cure.
Old Aug 20, 2006 | 07:17 AM
01 r/t's Avatar
01 r/t
im deffintly considering a tranny fluid change, i just started running mobile full-synthetic and i noticed after about 2 weeks the oil has burned more than an 8th of qt. Does anyone know the procedure of changing the tranny fluid?
