HP per lb of boost
Old Aug 23, 2006 | 04:17 AM
fastloudfzr's Avatar
fastloudfzr
Default RE: HP per lb of boost
so yer telllin me that it will run good with boost but when i'm not boosting it will run to rich so i need something to adjust the fuel pressure while i'm driveing
Old Aug 23, 2006 | 04:26 AM
fastloudfzr
how about the cartech fuel pressure regulator
Old Aug 23, 2006 | 01:07 PM
03neonRT's Avatar
03neonRT
ORIGINAL: fastloudfzr
No.
Cartech, Begi, and Chill Factory are all good RRFPR's with good variable rates of gain.
Old Aug 23, 2006 | 02:01 PM
fastloudfzr
MPX 60mm throttle body, Indy intake manifold, AEM adjustable cam gear, crane # 12 or 14 cam, the ultra performance bottom end rebuild kit with 8.6:1 turbo pistons .20 over, Hahn racecraft stage 2 turbo kit , Greddy type r/s blow off,Greddy catch can with mounting bracket, Apexi turbo timer,crane valve springs and titanium retainers, Indy stainless steel valves,MSD coil and wires
thats all the stuff i had in mind and now its like is it really gonna get me where i wanna be, but what else do i need?
Old Aug 23, 2006 | 02:55 PM
tooslow's Avatar
tooslow
just tell the people at hahn when you order you want a portfeuler instead of return line system. It will cost you more but it you should be able too reach your goal of 300h/p
lose the indy intake mani get a msd ignition controller
oh and you will need a clutch
Old Aug 23, 2006 | 02:59 PM
03neonRT's Avatar
03neonRT
Your also going to need a new clutch, and if you go even further than 300whp you'll need to start looking at new axles...but stock axles should be fine for your 300whp goal...
