HP per lb of boost
Old Aug 21, 2006 | 11:28 AM
fastloudfzr's Avatar
fastloudfzr
Default HP per lb of boost
so i'm officaly gonna rebuild the bottom end and new valves and springs in the head with a cam what is the approximat amount of hp per lb of boost does anyone know? I wanna get about 300 hp so gonna get the bottom end kit the indy intake 60 mm throttle body cam #12 cam gear msd coil and wires and the hahn kit any idea if 300 is possible?
Old Aug 21, 2006 | 04:22 PM
tooslow's Avatar
tooslow
Default RE: HP per lb of boost
yes if it is tuned right. but it is gonna be pretty hard too get 300 with a rrfpr setup
Old Aug 22, 2006 | 01:10 AM
fastloudfzr
whats is rrfpr setup?
Old Aug 22, 2006 | 01:17 AM
clean_sx's Avatar
clean_sx
if you want nitrous in your future, get a number 14 cam
Old Aug 22, 2006 | 06:06 PM
03neonRT's Avatar
03neonRT
ORIGINAL: fastloudfzr
Rising Rate Fuel Pressure Regulator.
If you want more boost you'll need a better way to control the fuel managment...so you would need either MS or a PortFueler type setup. HRC sells the PortFueler for $1,000 i think, and wiht their stock 16g turbo you shouldnt have any trouble getting 300hp...if you want more than that you would need a larger turbo, i.e. 20g or similar.
Post #1000 F' Yeah!
Old Aug 22, 2006 | 09:58 PM
tooslow's Avatar
tooslow
rrfpr setup are good but if you wanna boost past 14 psi you are just putting way too much stress on the feul pump. the pressure just get too high.
Old Aug 23, 2006 | 01:02 AM
fastloudfzr
well the turbo kit comes with the upgraded fuel system the injectors and the fuel pump so is that what you ment
Old Aug 23, 2006 | 01:32 AM
tooslow's Avatar
tooslow
ok you should read up as much as you can before you go turbo
but here is the feul basics
most kits for the neon uses raising rate feul presure regulater rrfpr
ok since they send you larger injecters you are gonna whant too trim the feul for when the car is not boosting and does not need all that feul. with the rrfpr setup you make the base feul pressure lower here is little formula too work that out (stock injecter size / new injecter size) times stock feul pressure= new base pressure
ok here his how rrfpr works for 1psi of boost it raises the feul x amount. So if you have a 8:1 rrfpr it raises the feul presure 8psi for every 1psi of boost.
I hope this makes sense too you
Old Aug 23, 2006 | 02:20 AM
fastloudfzr
so what do i need to compensate for this
Old Aug 23, 2006 | 02:37 AM
03neonRT's Avatar
03neonRT
But he is already talking about wanting 300whp...in order to get their your going to need more than 14psi on a 16g turbo, which means he cant use the RRFPR setup reliably...plus he has already stated he is buying the HRC turbo kit (instead of the custom SRT route), so since he obviously has the money to invest in this he might as well go HRC PortFueler or full MS for fuel managament right?
