Exhaust 2004 sxt with sway bar
Old Aug 26, 2006 | 01:58 PM
billyjoe's Avatar
billyjoe
Default Exhaust 2004 sxt with sway bar
I have been looking high and low... every exhaust I find for a Neon states that it fits with out the sway bar.... I have a sway bar on my 2004 SXT Neon.
I have been looking at the Borla and Magnaflow, the full sets I have found there are for neons with out a sway bar.
Is there something I am misunderstanding?
this is the ones I was looking at.
http://www.borla.com/applications/lo..._System/14862/
http://www.autotrucktoys.com/neon/Ma...10158C158.aspx
Thank you for all your advice.
Old Aug 26, 2006 | 02:55 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Exhaust 2004 sxt with sway bar
I'm a little bit confused as to what exactly you're asking, but I have a sway bar on my car and my exhaust fits no problem. Either one of those that you're looking at will fit, and should do so with ease.
Old Sep 2, 2006 | 03:13 AM
srt boy's Avatar
srt boy
I had the same problem when i installed my magnaflow exhaust all you have to do is pull of or unbolt the sway bar and add a 1.5" to 2 " spacer just above the bushing on the sway bar mounts.That should lower the sway bar enough to give clearance for the exhaust to fit.
Old Sep 25, 2006 | 06:51 AM
billyjoe's Avatar
billyjoe
Awsome thank you.
