Help me please!!!!!!!!!!
Old Sep 24, 2006 | 02:27 PM
gfiles77's Avatar
gfiles77
Default Help me please!!!!!!!!!!
2000 Neon SE my wife just went to the gas station on her way to church and when she came out it wouldnt start.
you turn the key the 1/2 turn and everything works, turn it the rest of the way and nothing from the starter
checked Fuses, relays, and plug is connected to the selenoid battery is showing 13 volts
anyone have any ideas it dosent even try to turn
could it be the Neutral Position Sensor and if so where is it located on the neon
Thanks
Old Sep 25, 2006 | 07:44 PM
spudsterier's Avatar
spudsterier
Default RE: Help me please!!!!!!!!!!
try putting the car in neutral and starting it....that should tell you if its the switch....and try all the gears while your at it.....if that is the problem, its located on the lower front of the trans.....if you look from underneath the car it should be the first sensor you see on the front of the trans
Old Sep 25, 2006 | 09:41 PM
Beauff's Avatar
Beauff
Try the easy things first. Clean your battary posts & make sure that they are on tight. My 96 neon has this proplem about every 6 mo.
Old Sep 25, 2006 | 11:10 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
as spud said, its possibly a problem with the transmission (auto) having to be in P or N. Once had a sensor go out in a Probe, it wouldnt let the car out of park cuz the sensor that told it the brake was on was broke. haha, anyhow check out that connection on the front of the tranny!
