fog lights?
Old Oct 2, 2006 | 02:54 AM
  #21
Izero's Avatar
Izero
Default RE: fog lights?
well if u want to use a switch, you can prolly just goto radioshack and buy one that is unless your lights didnt come with one.... as for my switch i think that i am going to mount it just above the petals there seems to be a good amount of space down there.. so i might just drill a hole or two in the plastic and then just secure it with a screw or two.... as for the power i am not sure where to set the wire up for power..... any suggestions?
Old Oct 2, 2006 | 03:07 AM
  #22
unleashedcc's Avatar
unleashedcc
well if u go to my domain, i have 3 switches. 2 r infront of the shifter, by the cup holder, and the other one is inside the armrest, the lil space for ur phone. the ones by the cup holder are for inside neons (left) and outside/underkit neons (right) the one inside my armrest is for all 4 gauges. bought the switches at advanceautoparts for 7$ each, i strongly recommend switches with LEDs so u can see at night if they r on, been times i never new if my underkit was on or not when i had a nromal switch. now wiring. i have an 8g power wire from the battery thru the fire wall and it goes to a lil box/splitter. DO put a fuse. the splitter ia a lil box with one main inlett and 4 small outlets. then one power to one switch, another and so forth, each seperate. never split powers between accesorries, never get the same outcome, specially lightin. now the switches have 3 outleft, power , negative and accessories. You run the power from the splitter to the power of the swtich. negative u ground. the accesorie outlet is for all positives from ur neon tubes or wut not. the negative from the tubes u either ground or acn connected to the negative from the switch along with the main ground one. like i said b4 try to keep things accesible, dont really wanna go thru the hassle of findin and taking off panels to find the problem. hope dat helps
Old Oct 2, 2006 | 03:14 AM
  #23
Izero's Avatar
Izero
ok so where did you get the splitter box? and im not sure i understand what youre saying think you can explain a little more?
and just a sidenote, where did you get your gauges i really like them....?
Old Oct 2, 2006 | 03:26 AM
  #24
unleashedcc
splitter box i got it at a sound system store, u got msn or yahoo messenger, will be easier explainin there
Old Oct 2, 2006 | 03:50 AM
  #25
Izero's Avatar
Izero
i have aim: Izero29434 but im headin to bed atm so msg me in the morn... thanks :-D
Old Oct 2, 2006 | 07:26 PM
  #26
SupermanNeon's Avatar
SupermanNeon
I put them on today..switch and all..But when i tried to mount them i couldnt find a good place where they would sit with the bracket hidden like...I just screwed them into the black covers where the OEM foglights would be for now..I really didnt have time to remove my bumper just to get my fingers in there..Looks alittle ghetto but i guess with more time ill fix them..And im not worried about a few holes in my bumper..I plan on getting a body kit later so no biggie.
Old Oct 2, 2006 | 07:58 PM
  #27
unleashedcc
any pics bro?
Old Oct 2, 2006 | 07:59 PM
  #28
camlen1098's Avatar
camlen1098
ORIGINAL: SupermanNeon
I just looked at your domain and saw your pedals.....lol I have the exact same ones!! I know it's dumb but yea...
Old Oct 2, 2006 | 08:08 PM
  #29
Izero's Avatar
Izero
i'd love to see some pics. of the lights Super.... when you gonna have em up?
Old Oct 2, 2006 | 08:30 PM
  #30
SupermanNeon
gonna post them today once i get a second before it gets dark ..Like i said right now there kinda ghetto on there i want to take off the bumper and get them on there better but i dont know how to get it off..Gonna gave to go through my haynes manual!!anywayz pics will be up in a min.!
